i need help
trying to help a freind out.
hes got a gsr"b18c1"
Skunk2 IM
2000 Si Pistons “PR3”
ITR Camshafts
DC 4/2/1 header
Port/polish
adjus gears.
it will be dropped in a 90 gs.
As he is non obd and with all this work done and the head shaved a bit… hes atleast in the 11:8 compression.
Will the stock injectors work or will he need to upgrade.
Also he will be running pr3 with v-afc. is that sufficient?
Please advise.
I would think the stock would be ok, he should get a fpr that should give him the extra fuel me might need.
so using a 1.6l ecu to run a 1.8l engine with bigger cams and bigger pistons is not a danger?
i dont want him blowing up his engine.
what should he do…
can anyone help me?
Anyone?
64 views and one reply???
