Yeah that gas stuff really works, I know this first hand. It’s called heet buy two bottles and use it with half a tank. Heet is used as an antifreeze for your gas and to remove water from your gas, so the car wont run as good until you use that stuff up. It wont do any damage if you use it.
i just came back from walmart and didn’t see this HEET stuff…so i bought some max life oil, fuel injection cleaner and octane booster.
i’ll hit advance tomorrow morn
any other words of advice on getting these numbers down?
i dont think removing a plug would be the answer. unburnt fuel creates more contaminates. for my test i used my vafc to lean everything out and i was well under the requirements. so im assuming a missing plugs would cause some pretty bad test results.
well theres still other parts you have yet to replace as part of maintance(fuel filter, distributor cap/rotor…etc). changing plugs and wires won’t make that much of a difference in smog reduction. and like i asked before, how old is the o2 sensor and cat? chances are both could not be functioning efficiently and need replacing. put back on your stock intake too.
i just bought a new o2 sensor and as for the cat is the stock system. My friend has a 92 SEr with a rebuilt motor that he built and we actually went through emmisions at the same time…here is the joke
