IS IT TRUE THAT YOU CAN USE A (IAC) IDLE AIR CONTROL VALVE FROM A 1994 HONDA DEL-SOL DOHC V-TEC , ON A 1ST GEN B16A JDM …PLEASE HELP OUT BECAUSE I CANT FIND A (IAC) ANYWHERE!!!
I think I have the part you need, almost new. Are the bolt holes farther apart than on the the B17. if so the ansewer to your question is yes the 94 will work. It is a 94 that I have.
