I’m having serious problems with the Idle on my car.
I know there is a similar post going right now but I want a little more attention. I have literally racked my brain for hours trying to figure out whats wrong. So far it’s teg - 2. Travis - 0
I read the Post in Teg Tips and have searched many times to try to figure out whats wrong.
When you plug both holes inside the TB, should the engine Stall?
If it does stall is the IACV to blame?
So far I’ve:
Checked the TPS
Checked the Thermostat
Dismantled and cleaned the IACV
Dismantled and cleaned the FITV
Checked all Vacuum lines
Checked for loose TB
Checked for loose bolts on IM
Checked for Sticking Throttle cable
Checked for sticking Butterfly valve
Replaced the relays for the Cooling fans
Checked the Coolant temperature sensor
Checked the coolant temperature switch
Any help would be greatly appreciated.
Thanks,
Travis
