identifying head codes
ran across a DOHC VTEC head that was stamped pr3-4. Guy claims it is off a DB2 gsr. I didn’t think the heads off the gen 2 gsr’s were stamped with this. thought it was going to be p61? could someone verify this and tell me what the pr3-4 went to?
take a pic…i have heard the stamped dates are the true telling…some say its a ITR some say B16
I will tonight. Would you happen to know what the gen 2 gsr head is stamped?
its stamped with the year the car was made…if made in 1992 then its gonna have say 92 on it and 1993 will say 93 on it…right on the front of the head…just look closely and you’ll see it.
i got that much.
I also know most heads are stamped with the ecu code. for example the one in questions has pr3-4 stamped. I would imagine the gsr one has p61 stamped but i also know the b17 is more or less a knock off b16 so i didn’t know if the head would be stamped with pr3 instead. this is in addition to the year stamping.
if it wasnt so cold i would go look at my gsr and tell you, haha. when i do i’ll letchu know bro.
They’ve got the same heads, but different cams and P61 stamped intake manifold
sounds good. don’t forget about me. :slight_smile:
so would this mean they are stamped…?
My db2 head is stamped pr3-3. Not sure if they all are.
thats what my 1st gen b16a is stamped too
from what i can remenber the b17 is b16 for the most part. This would explain the same stamping on these two heads. wonder if anyone on here that has a type r can chime in with their head stamping.
Whats weirder is the head i’m talking about i was thinking it might be a type R head but the date stamp on it is 92.
[QUOTE=ls/vtecstitch;2122499]
so would this mean they are stamped…?[/QUOTE]
PR3. B16, B17, and Type Arghs are all cast PR3
GSR’s are P72
^^^ thanks mrpenny! :slight_smile:
do you know what the difference between the pr3-3 and pr3-4 are?
I actually just google’d “difference between PR3-3 and PR3-4” and came up with this: http://www.honda-tech.com/showthread.php?t=898679
From the looks of that thread, there is no difference. But there is also contradictory info in there as well, so I guess keep searching. I’ll be picking up a hype R head tomorrow/today from a legit seller, so I’ll let you what the casting on that is
sounds great. keep us posted.
