Idle and brake problems
Hey everyone,
I have these wierd problems with my idle and brakes.
  1. when I am sitting still at an idle the car will idle at 1kthen it will idles really low then surge back up to about 1k, it will idle down to about 300rpm’s maybe and go back up, stay at 1k for about a minute and slowly fall back down to 300. It never dies on me but thats what it does
  2. If it isnt doing that is is jumping from 1k to 1.5k rpms while braking below 10 mph then once stopped it will idle normal
  3. If i am driving kinda hard and stop it will jump from 1k to1.5k for about 30 second to however long I am stopped then the next time I brake it is fine
  4. when braking I only have brake pressure for about 5 seconds then the pedal mushes to the floor, unless I am idleing down the gears and when i clutch in and stop the brakes will mush/loose pressure/fade
  5. I have this wierd squeeking noise coming from the right front side all the time, accel, cruise or braking but when I am sitting still it is not there
I am guessing a vacuum leak, bad pcv valve, bad brake booster or air in the brake lines.
but if anyone has had these similar problems and can help narrow it down or guide me in the right direction I would greatly appreciate it.
I am not really trying to spend hundreds of dollars, nor am I looking for handouts. But my fiance just had our baby sunday and I need these problems fixed. Cant put a child in this car. But in the meantime we have an 03 Grand Cherokee to use, but we will not always both be home and she can not drive a stick.
Sounds like your booster is junk whick could be your idle problem also if its bleeding vaccum off
it might be one of your sensors on the intake manifold…
WOW, I just called standard auto parts and with my shops dicount the brake booster is still $153. Would any of you trust using a junkyard booster? Also I just checked and my pcv valve isnt hooked up at all, it must have broken when I put the intake manifold back on the engine. I broke on the bottom side.
