Okay, so here goes…
I finished installing my Skunk2 Intake Manifold today and I’m currently experiencing some high idle and surging idle issues. When I first start the car, it wants to idle around the 2500-2800rpm range. Then, after it warms up, it will surge from 1000-2100rpm (give or take, some times higher, but that rpm range seems to be more the more constant range).
I used some Brake cleaner around every possible spot for any kind of intake manifold leaks and got nothing. (for those that don’t know, brake cleaner/carb cleaner sprayed into possible manifold leaks will cause the idle to change dramatically for a few moments, thus potentially pinpointing leaks)
I sprayed every inch around the top, sides, and bottom of the intake manifold, so there aren’t leaks at the manifold/head mating surface. That much I’m sure. Couldn’t find anything around the throttle body, either, but I didn’t do too much spraying in that area, honestly.
I’ve been told that it could be air in the coolant lines, but I went through the burp procedure 3 times today, and after the 1st “burping”, I received ZERO bubbles. Neither small, nor large. So, from what I can tell, there is no air in the coolant system.
The FITV wasn’t messed with, as it was still attached to the throttle body and was untouched during the swap over. The IACV was also not messed with in any way, but I’ll be taking it off tomorrow to inspect it for dirt or potential seal issues.
I believe, after driving, that my throttle cable might be a BIT too tight, so I’m going to release a small amount of tension (maybe 2-3 threads, or so, on the adjuster) But, that definitely wouldn’t cause the idle to surge.
Also, when driving, if I’m driving at low speeds (below the 2500rpm range) the car drives almost normal, but if I go WOT just to see how it responds, it seems to bog for a split second before taking off as normal.
As far as information goes, that is all I can come up with, but I am looking for any insight and suggestions as possible as to potential causes of this idle surge.
