I have a 1992 integra gsr I am having a problem with my idle not idling at 800 rpm at normal operational temperature. I am thinking it could be a cause of the FITV (Fast Idle Thermo Valve). I did see one of the hose is leaking coolant. I am planning on replacing it today after work. Does anyone else have any suggestions?
Is it idling high or low?
the car idles at 1000 rpm at normal operational temperature. The needle does jump up and down at +/- 100 rpm every 2 to 3 seconds.
Any advice???
Problem fixed rough idling was caused by a leak vacuum from the map sensor port.
How did you find the leak? I’m battling my own idle issues…
Ng
[QUOTE=ng8650;2227708]How did you find the leak? I’m battling my own idle issues…
Ng[/QUOTE]
One of the hoses behind the manifold came loose. I must had accidently unplugged it when I was installing the manifold. I plugged the hose back in and it runs fine.
