idles set screw
i was wondering if the idle set screw is supposed to be very hard to get completely out of the throttle body i need to get it out to put in my other motor any and all suggestions are greatly appreciated
Nobody can help with this???
Yes, they are an absolute bitch to take out. Use a larger size flathead screwdriver and make sure the tip goes all the way into the slot. Otherwise you will strip it.
just use an impact driver. you’ll screw it forever trying to use a regular flatblade. it’s made of brass, so it may start to chip away. have to take care. it’s the o ring that causes it to bind
