i am assuming that the shift linkage is too right??? and clutch??
i should know this…just checking
Shift linkage I’m not familiar with, but clutches are not interchangable. I always stand for correction. HTH
clutches are interchangible to a certain extent. If you have an 89-91 tranny then you need a 90-91 integra clutch. If you have a 92+ tranny then you need a 92+ integra clutch. From what i’ve seen posted it doesn’t mater if the tranny is hydro or cable, LS or GSR, all the clutches are the same, oh and the 99 SI’s clutch should be the same as well. I think however the ITR clutch may be different, but i’m not positive.
i don’t believe linkage will be interchangible (some may be, but definitely not all of them). Any b series linkage should bolt right up to any b series tranny, but it may not put the shifter in the right place, or may have interference problems with various things. For example, if you put a b16a into an 89-91 civic you can use the 90-93 teg shift linkage, but it needs to be shortened and welded back together to make it work.
The ITR clutch is the same as the 92+ Integra and the 99-00 Si. Only real diff. is that the flywheel is ~4lbs lighter.
