If Sparco Sprint seats fit in a 1995 - 2001 Integra, do they also fit in a G2????
Just wondering if anyone knows the answer to this??
Im buying Sparco Sprint seats from someone and they said it fits in 95 to 01 integras.
I was wondering if they will mount up to OUR generation integra??
anyone know??
The seats are universal, you’ll need car specific mounts though.
If you want to do it 1/2 ass, you can use the 3G mounts, but it would be the same as fitting OEM 3G seats into your car - only 3 bolts work and the seat will be crooked.
sup bboy! hey man I got Sprint seats and Sparco sent the wrong seat brackets to me. So honestly, I don’t know if they make brackets for a G2. But like SE-37 said, you could use the G3 brackets but only 3 of three bolts will fit. For safety reasons I decided to get mine custom made to fit… it’s up to you - later
yea, im getting mine custom fitted, Keep Labs is making it sit a bit lower and slanting it back just a little bit for more comfort
i got sparco speeds in my teg… got the brackets from sube sports…they really don’t fit but they do now… got pics of the seats installed under my member name…check em out
try this if you like it worked for me.
you know if you can use the bracket off of a g3 teg, you guys can take off the bracket on the side with the seat adjuster is on your g2 and bolt that on to the bottom of the sparco or any honda seats. i had that problem, my cousin figured it out for me. i think you guys might want to try it. cause i had si seats for awhile, cause my original teg seat snapped at the pivot point if you know what i mean. and the si seat left me with three bolts also, til he showed me that.
