ignition?
Before i start i have checked and checked and i can’t figure out why i have done research tell me what you think… btw its not my battery or alternator or something simply like that.
So i was driving my 1993 GSR last night and after i left the stoplight,(driving normal) i was in second gear around 2.5-3k rpm when one of my 10.4mm thunder sport spark plug wires fall off of the dist. cap. this has happened a few times before so i pull of the road by turning left. Well i was turning the engine died (thats unusual) and the power steering stops working. so i pull off the side road and am in the break down lane of an exit off of a highway. well i get out of my car and put the spark plug wire back on the car and secure it back in its place. i then hop in and try to start it well the starter starts crankin over but the engine won’t fire off…really sounds like it wants to and it almost did but it didn’t. The dist cap and rotor are brand new from honda i put them on a weak ago. so now we are down to a problem. i am not getting any codes from the c/e light, i can hear the fuel pump whining when i have a friend turn the key while im by the gas tank. the spark plugs look red-maroon around the conductor and the prong all four are the same. i checked the injectors and they work fine. the problem has come down to ignition… so what do you thing i checked the rotor and cap and the look fine no burnt wires inside the cap. is it a fuse? if it is what fuse could it possible be? i checked and the starter and alt. fuse are still good. im am stumped on this any help would be appreciated. thnx
PLEASE HELP ME I AM STUMPED :bang: :bawl:
Check your coil and change your igniter. No place for the spark to go when the wire came off, good by coil or igniter.
i have an internal coil… how would i replace that?
andwhere is this ignitor
Do not use “HEEELLPPPP” in your subject EVER AGAIN. You need to read the FAQ. I usually lock these threads.
well thanx for the help… i thought these forums were here so people could get help and such… guess not…btw whats wrong with help as my title?
Lumina- your help title is no good and you should know that because it is in the faq that you are supposed to read that your never supposed to just have a subject that sauys “Help” or “question” because there would be a million of them. Im not trying to be a jerk just letting you know whats up. Also my car did the EXACT same thing as yours yester day shut down while driving, no ps, cranks but wont turn over. You probiiibly have no spark either. Did you figure out what is wrong yet cause I would really like to know.
