This weekend was my first chance to do serious work on the Integra, so I took Friday off and decided it was time to commit to the bushing and suspension replacement. Being a veteran, it also was a pretty great chance to shut off my phone and reflect on stuff from the past while I was busy getting filthy. Even put my garage bunny daughter to work turning wrenches, at her own request.
Hope everyone had a great Memorial Day.
I’ve been collecting parts for almost a year now, and highlights for the weekend were:
- OEM strut & spring replacement - Tein Street Basis adjustable coilover kit, front and rear
- OEM rear lower control arm bushings - Energy Suspension bushings
- OEM RTA Bushing replacement – Prothane kit
- New Brake Rotors and Pads
- EBay strut tower braces
- Skunk2 rear camber kit
- Smaller jobs: sunvisor repair, pedal pad refresh
All of this was done in my garage, on the floor, but I had a plan and it worked out really well. A while ago I had purchased a Kobalt corded impact drill anticipating this job, and it more than paid for itself. Also rented a coil spring clamp tool from Oriley’s, which helped that part of the work move smoothly. Jdecks build thread on G2IC has really inspired me over the months since I picked up this car, so I tried to be organized and fairly patient like he has been, with excellent results, lol.
Hate me some frozen and rusted rotor screws.
When I got under there and started pulling stuff apart, I found that the car had been dealer serviced and kept super clean, so no visible issues other than age/deterioration. There is more body rust on the rear quarter panel fenders than under the car! I did see an exhaust leak at the muffler, so an axle-back may be next. One of the front springs had also cracked and broken in several places, and it looked like moisture had gotten inside the rubber spring covering and eaten the metal away.
The RTA bushings were squeaky as hell since I bought the car last year, so I knew those had to go. I ended up smacking the old ones out with a hammer and punch tools from Harbor Freight (love that place!), and then I used the punch to seat the new Prothane bushing. You can see that I marked up the sleeve pretty good, but it went in true.
I had never done coilovers (actually any suspension work, ever) before, so I went pretty slow and took my time. The Tein coils require components to be reused from the OEM damper stuff, so I was able to clean up and repaint some of those 26 year-old pieces in the process. Everything went back together fine, and just to be sure I had my local shop check everything over this morning when I brought it in for an alignment. Now I know tons of people here swear by Koni/GC, but for $500 shipped I got a steal on a perfectly good aftermarket coilover setup out if the box, and did brakes/rotors/bushings/new tools/ etc. for what it would have cost me to do the best in class suspension setup. No regrets.
For the rear lower control arms, rather than burn out old rubber, I decided to melt the rubber and then hacksaw out the rings. I used my shop vice to press in the new stuff, and that part was simple.
The eBay cross braces make a noticeable difference, despite their garbage build quality and workmanship.
One haggard repair was the plastic brace for my sunvisor, which had cracked in half. I found a replacement at the scrapyard, but it was from a tan interior, so I got out my Testor model paints and had some fun. You can’t tell the difference now, haha.
My Rota wheels were filthy from the previous owner, and I had not yet had a chance to deep clean them, so I took advantage of this opportunity. Eagle One wheel foam is amazing, highly recommend.
It took me 3 full days to get everything done, and I still have the entire front set of Energy Suspension bushings because the fronts basically looked good still from the factory. Maybe sometime I will look at a “Part II” of this project, but I am not worried about it right now because everything is good at the moment. The ride is a bit stiffer now, but everything working together, on new rubber, feels like a completely new car. I have a decent drop, and the wheel gap is a huge improvement from the stock rally car look, but I don’t have plans to slam it. Since this is my daily now, the modest drop is good enough for me. Awesome results for a ton of sweat and dirt over the weekend.
One footnote: the knowledge base here and on YouTube is vast for the 2nd gen Integra, and was quite valuable to me when I hit a snag or forgot which way a bolt goes in or something. Thanks to all who have lent their advice or recommendation or wisdom over the years. If anyone has questions or comments, I welcome them on this thread. As a very amateur wrench-turner, these types of conversations on other forum threads were very helpful to me, personally. Thanks.
