Infinity 605cs Component Speakers
Originally posted by BobyYoo
i mean, does your door vibrate with those speaker, they look pretty poweful… so i thought you have to put something on your door, like a foam or something similar like those noise dampering such as dynamat to reduce the vibrating from the door
ok, now that makes sense…sound dampening on the door. My door will rattle a little with some music. But really my bass isn’t up that high for the comp set. I used to have my amp set so it was boosting 6db or so, but now I turned it back down ot 0db. It sounds much better this way. The lows are clearer, yet not quite as loud…which is perfectly fine since i have a sub to do the major pushing of lower notes.
I personally don’t like dynamat cause its expensive and heavy, and to me, the increase in quality of sound just wouldn’t be worth either the price or the weight. but maybe for you it would be. I suggest you try it without and then if you decide you need it…then get it.
I have the Infinity Kappa 63.5I’s, they sound great! especially with an amp hooked up to them… Install very easy, just cutoff basket and screw in, thats all. got them off ebay brand new for $98 shipped.
