Ingall front camber kit lube.
My ingalls front camber kit is squeaking and I want to take it out and lube it.
Will I have to get an alignment after I do this? As long as I don’t touch the adjustment nut I should be okay.
Has anyone done this without getting an alignment?
Thanks
you can do this, but in my “professional” opinion, for max results always realign your bad boy.
now saying that, yes you can take it all apart and put it all together without an alignment. just make sure you make a tick marks with a paint marker on everything. i mean everything-bolt-metal-mounts-outline the brackets-the nuts…pretty hard deal. the bolts go through holes, the holes are bigger than the bolts. so when you put your setup back together, it can vary a total of what…a quarter or eighth of an inch…which equivocates to a non-aligned car.
just take your time and and mark everything you take apart carefully.
