go to:
www.island-kine.com/g2ic/camber.html
questions email me or if you would change anything email me and I’ll make the changes.
go to:
Link doesn’t work.
Regards,
Oz
Looks good. However, you do know, there is a support beam that connects both ends of the control arm right? And sometimes, this beam can be a bit(h to remove.
Just FYI,
Oz
camber kit
what kind of camber kit do i need if i get skunkworks coilovers and gonna drop it around 2-2.5 inches.
get the kit that can be adjustable to up to 3 degrees for a drop like that.
i dont know if this is common for sedans or not, perhaps it was just my eibach sportlines, but i could not remove that rear bar w/o dropping the shock. just needed to remove the lower fork-to-lower arm bolt and top of shock-to-body nuts, drop it down a few inches, then she came out. a bitch indeed
I want to only drop about 1.5-1.8 inches. Would the non extreme kit be sufficient for the front?
im on eibach sportlines 1.8"front and 1.5" rear, and adjusted the extreme kit to the maximum. when i got it aligned, they didnt even need to adjust it. i think my results were like -.06 for the elft and +.07 for the right. im riding on 205/50/15 fyi
so get the extreme to be safe
rcnacura can i use your write up on my site ? looking to build a how to database. credit will be sent your way as well as a link to your site
yah go ahead, but it will probably be taken off the site soon since that client isn’t renewing their domain contract. but copy the whole thing if you want. I’ll move it over to geocities when I have time.
rcnacura i might be able to host you. i gotta see whats going on first…
s2k…alright. Just let me know. BTW I’m robert (red 4dr teg), have I met you at a meet b4?
yup we met around… 4 years ago i belive or 3 when your car was stock. We went to the raceway but it was close. The chubby asian dood… yeah thats me
didn’t u have a yellow crx?
yeah i think so…
