i just installed an ingalls front camber kit on my friends 93 accord coupe. its just like doing it on the teg. when we dropped it down, little arm is sitting on the inner fender thing. how do we fix this. the horse shoe thing is totally rubbing the inside fender wall and we want straight camber but is it possible?
The instructions on my Ingalls camber kit say that adjusting for more than 2 degrees might cause your problem and you should modify the fender lining. HTH
Ben
thats what happens when its adjusted that far. Happens on tegs too. My upper control arm has worn a pretty good size bump on the inner fender, and even pushed through the double wall and now has a little bubble on the strut tower. Its not really a big deal, the arm should just force its own way and make its own little divet so it will clear. It won’t hurt the car structurally.
Shenrie even went so far as to cut big holes in his strut tower to allow for his upper control arms to have clearance.
check it out:
yheai used a hammer on mine, ill do what shenrie did tomorrow
i have those bubbles too
