Ingalls Kit Question
What is the differnece between these too? Ingalls Extreme Front Adjustable Camber Kit w/Polyurethane Bushings AND Ingalls Extreme Front Adjustable Camber Kit w/Polyurethane Bushings
there the same thing
lol
mabe u ment etream and non extream
extram gives ±3degs
reg is 1.5 i bleive
if u meant rubber/polyurthene…
rubber=wont sweek
poly will=-
lol ah man sorry copied same thing twice. the differnece btwn. this Ingalls Extreme Front Adjustable Camber Kit w/Polyurethane Bushings AND Ingalls Extreme Front Adjustable Camber Anchor Bolts
because they look the same. http://www.iapdirect.com/catalog_items.asp?cat=Suspension&catid=1
If you take the part numbers from that site and cross-reference them on the Ingalls site, you will see that the only difference is that one has the poly bushings (35720), and the other is rubber bushings (35730).
I think that site just has the one labelled incorrectly.
