On my front tires the inner part of the tire wears dramaticaly ive had the tires on the car for about 3k miles and the wear is verry noticable. What is causing this? This only happens on the front. Any ideas?
If u recently lowered ur car, its because ur camber and/or toe settings are off. U a camber kit to correct the camber and just bring it to an alignment shop to dial everything in to spec.
This is not camber wear…i know what camber wear is. This is on the extreme inside of the tire the rear wheel has more camber but dose not poses this kind of wear.
So stop the smoke shows:up: ![]()
If u have bad camber along with wheels that have a an offset that pushes the wheel closer in the wheel well, u may be rubbing on the frame of the car…check if theres any shiney metal showing under the wheel well where the rubber may be touching.
Otherwise, u need to adjust ur tie rod and correct the toe settings. In any case, an alignment is the best option to get all that straightened out.
toe alignment is off.
messed up toe eats up the tires really fast
