I have some 510cc injectors I’ll be using with my LS turbo setup. I received a flow test result sheet with them. Two got a rating of 518cc and the other two got a rating of 521cc. Which injector size should I type into TurboEdit so it can rescale my fuel map?
What make of injectors are they? I would think you would be fine with 510cc. Even better if you were able to input the injector dead time to correctly control the injectors at any given specific voltage.
They are EV1 style, 510cc Denso injectors from a Lancer Evo 3.
Those are great injectors. If there is no graph in which you would input injector dead time numbers then if you choose the 510 cc injector size in your tune you should be just fine. The tune will adjust the calibration accordingly and then you have to tune the fuel map to make your car run.
Sounds good, thanks for the help. ![]()
