Hi everyone, I took out my seat belts and installed sparco harnesses. I started my car and my seatbelt warning started beeping and wont stop. I searched the old threads but I even put in the papers clips in the adapters under the seats and the seat belt apapters attached to the seats, and it still keeps beeping. Can anyone please help me stop this noise !!!?? I also have a small oil leak coming from the oil plug drain, any suggestions on that also ? Thanks again everyone
beep beep beep beep beep beep beep beep beep beep beeo beep beep beep beep beep beep beep beep beep beeo beep beep beeo beep beep beep beep beep beep
i have the same thing but i only have one front seat!!
seats
ok on the passerger side kick panal. you will need to take this off and then you will see the seat belt brain. if you dont have the seat belts jist unplug the the harrness. that all, the beeping should stop. if you need a ny more help my AIM is bigksoda
Re: Insanely Annoying Beeping ! HELP !
Originally posted by Fastkidspeed
… I also have a small oil leak coming from the oil plug drain, any suggestions on that also ? Thanks again everyone
try getting some new oil plug gasket.
okay did you reconnect the wire attachment on the belts? if not you can put just put a jumper between the two wires, cause all the belt does is connect the circuit. The leak is because of the crush washer. Everytime you change your oil you should replace the crushing washer (like $.40) it creates a firm seal beteen the plug and oil pan.
thanks guys - about the seat belts , i got it to stop beeping , just gotta change that gasket like u guys said - thanks again for the help !
