Install/Review: EBC Rotors + Green Stuff Pads + Techna Fit Brake Lines
http://superstreetonline.com/projectbuild/130_0412_flashback2/
is is a wonderful post. Thank thank thank thank thank you very very very very very very very much. Just about to start my brakes this month, already have them torn down. Now i can do it step by step and not mess it up. Plus i was already plannin on ordering the techna fit lines :smiley:
The techna-fit lines look like they only include 2 mounts on each of the lines - stock uses 3. Do they recommend reusing one of the stock mounts, or just going without?
Yes, I jacked the old mounts off the stock rubber lines with a chisel and hammer. Those front lines need to be secure, with the turning and such. If you look at the mounting tab on the stock lines theres a flap of metal bent around that keeps that mount on, just chisel it back enough to open it up.
I would also like to recommend installing speed bleeders at the same time. When installing the rear lines the caliper gets in the way and needs to be removed, but the fronts were clear so I did them first.
Touge tuning used to show up in the sponsor section. They sell techna-fit lines for 80 + shipping (10 bucks for me). Use paypal to pay by credit card!
http://www.g2ic.com/forums/showthread.php?t=167785
