I installed brand new skunk2 shocks & springs on my Integra today, I reused the stock mounts. I had all four wheels off and the car on stand, everything bolted in rather smooth for a 21 year old rusted out car.
I jacked the car up, removed the 4 stand and lowered the car. I look at all 4 mounts and they shot up like 4" wtf??? I’ve lowered other cars before and I’ve never seen this before. Everything is on tight, I drove down my residential street going real slow and heard knocking. Ideas??
You were right, got the fronts done and they are rock solid.
I tried the rears. Starting from the top: Skunk2 Nut, oem washer, Skunk2 red bushing, oem piece (#14), oem mount, Skunk2 red bushing, rubber spring cap, oem washer, skunk2 bump stop.
This is everything that should be on there, minus the oem dust boot which was too rusty. The spring is rather loose in the assembly which is a red flag. With the spring/shock compress when this is installed making everything tight?
I have Skunk2 Pro-S coilovers and yes, the spring is loose on the shock. You have to do your best to make sure they will sit right when you lower the car.
