installing an aux cable in a head unit with no aux port...
first of all i did search and nothing i needed turned up so ill ask.
i got a free sony head unit from a buddy but it doesnt have an aux port to run my ipod and i have no antenna so i cant listen to radio or use a fm tuner…
any suggestions?? also on a side note, my hid ballast make a high pitched whine that makes my shitty reception even worse, im sure this aint normal but any ideas? all comments are must appreciated
Would have to get a wiring diagram to figure out what wires to cut, but this could work.
thats a seriously bad ass right up, thanks man
If the head unit does not already have aux inputs you cannot “add” them to it. I can’t eve thing where to start to tell you how wrong that thought is…
:umno:
Sorry just looked at the link, however if you aren’t an electronics EXPERT, you should NOT try this!
If your Sony HU is a CD changer control unit an adapter is avalable to turn the CD port into a changer port.
Another option is to get a “hard wired” FM modulator, an antenna is not needed for it to work.:whisper:94
Hey man, my deck is Pioneer and as long as you have a ‘CD CHANGER’ input you can do this. You just have to isolate or find out whichc wires are which…
Once you know this, you grab yourself a 3/8 stereo jack from the source and you hook up the R and L = and - to the appropriate place on the jack…Set your deck to AUX and you are set!
this worked flawlessly on mine and saved me the 60 bucks.
Hope it helps.
[QUOTE=lksdG2;1968059]
any suggestions?? also on a side note, my hid ballast make a high pitched whine that makes my shitty reception even worse, im sure this aint normal but any ideas? all comments are must appreciated[/QUOTE]
How do you know your ballast is the culprit that’s making the high pitched noise? High pitch noises are a sign of a bad ground somewhere. Do you have a system in your car… maybe you ran the ground together with the power lines thus may cause a whining noise.
Go back and check all your grounds coming from the ballast or sound system…
i bet thats what happend i hate fixing crap like that
Ditto! Running wires in the car is the worse! I hate having to take off panels here and there just to hide and run the wires… oh well… you gotta do what you gotta do right…
yea except doing a mercedes then you really hate life
