installing bucket seats with weapon r brackets
Hey guys so i am installing bucket seats with weapon r brackets…Three of the holes line up with some elbow grease…but the 4th rear hole which is by the center control which would be the right rear corner if sitting in the seat…it doesnt line up with the hole just quarter of the hole you can see thru the hole…im asking how did you guys with weapon R brackets install the brackets…is there some specific order or what…any help would be appreciated.
Thanks
From what I remember mine lined up pretty well. Are you tightening the other three down completely? You really have to get each bolt just barely started and then tighten them all down in sequence. If you get one fully tightened without starting the others then most likely another won’t line up right.
yea i did it and just had to push down on it and it did go in…thanks for the help man…just gotta do passenger side now
:gotpics: after your done. Show them off. :slight_smile: I’m waiting for my next paycheck to buy some weapon R bracket seat for my Sparco seats.
I will snap some quick pics of my f1spec seat set up with weapon r brackets
where did you buy the weapon r bracket and did the auto belt thing bolt right up…the one in the middle of the e brake?
i bought them off of ebay used ones got lucky in the auction…i believe from ricecooker…and the belts bolt right up some custom work had to be done so that the cover of the belts doesnt rub soo much with the ebrake plastic cover
