Im fuckin pissed, i cant seem to get to the connecter behind my head lamp to change my bulbs
Find someone with small hands. :chill:
it should be just a turn and pull
for the passenger side, take out your battery and take apart your stock intake…its much easier
the hardest part i found was pushing down on the clip of the bulb casing to release the bulb after you’ve pulled out the entire assembly…man that was tough on the fingers
Yeah i tried to turn and pull, just like the tail light bulbs but that mofo wouldnt budge
use a flat head to pry the headlight bulb out by the base and push down on the little tab and it should come out with no problems. with it not moving at all if it’s still inside the headlight housing, it’s not fully unlocked. still need to turn it all the way until you feel it get loose.
