Installing New Sunroof.
The Sunroof in my '91 GS is cracked fairly badly, but I have a new one.
Is there an easy way to replace this part?
when you find a way let me know cause i have to do the same thing .
its pretty simple. hope u guys can follow this. this is taken form the autozone repair guide form their site.
link: http://www.autozone.com/addVehicleId,1749602/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c15280049cca
be sure to follow the directions for the right year and model the include the 86 year and acura legend.
  1. Slide the sunshade back and open the sunroof. Pry off the rail cover, remove the mounting nuts and deflector arm pin. Remove the deflector.
  2. Remove the caps from the sunshade rail end and remove the mounting nut. Slide off the sunshade rail end.
  3. Close the glass and remove the mounting screws from the sides of the panel.
  4. Lift the panel up and forward to remove. Pull the sunshade forward and out of the rails, bending slightly if necessary.
hope this helps guys
