Is there a way to bypass the seatbelt lights/noise? Im going to install some harnesses in and i was wondering what i can do to bypass everything. Unless i just keep my stock seatbelts.
To stop the beeping,there is a little silver box located on the side of the passengers floor panel,its got a green plug,simply unplug it. Then remove the seat belt motor fuse and the light inside the cluster (IF IT BUGS YOU). But i think the light will stay off with the fuse pulled.
Cool bro, thanks!
