Intake cam locks up while rotating engine manually
So I install a new timing belt , change the water pump and tension pulley in the process.
After doing a valve job
I set the timing mark crank at tdc cams lined up facing each other.
My main issue is when I manually rotate the engine to do a full turn not even half a turn I notice there’s a lockup and the belt slips throwing off the timing mental note I have not tightened the tension pulley yet.
So pull off the timing belt set the crank back th tdc, set the exhaust cam back then I discover the intake cam is stuck. I loosen the bolts to the cam caps then I am able to turn it back and set it back to tdc. I retorque the cam cap bolts, reinstall timing and try again, same result when I rotate engine cam locks up belt slips timing gets thrown off…does anyone have.any idea what is wrong here…please let me know if you have.any advice or feedback.
Thanks in advance
did you adjust the valve lash?
Oh crap I forgot to do that… thanks
better run a compression test after it’s all buttoned up
Still locks up after valve lash adjustment …but it doesn’t lock up when its loosened…
