Hey guys,
This is a mod done mostly on H series engines. I havent found any write ups on how to do this on B series engines and I figured it out over the winter so I figured I might as well do a write up on it! ![]()
Basically what your gonna do is take the coolant that would normally run through the throttle body, fast idle valve, and electronic idle air control valve and back into the water pipe. This just take the coolant that would run from the upper radiator hose and just sends it straight back to the water pipe behind the thermostat! Instead of running through the manifold ![]()
This cause a vacuum leak in the fast idle valve so you need some sheet metal and rtv to use as a block off plate between the fast idle valve and the manifold. This in turn causes your cold start idle to be much lower and you’ll also never get the hunting idle problem again! On cold start my idle is at 1100 rpm (750 when warm) which is much easier on the engine’s rings! ![]()
Parts you’ll need:
2 Feet of Hose (I bought 3 just to be safe)
Rtv silicone
Small piece of sheet metal
4 vacuum caps
Tools needed:
Screw drivers to undo intake and hose clamps
Channel locks to undo hose clamps
10mm ratchet and extension to take off fast idle valve
This is the first hose to take off its runs from the upper radiator hose to the throttle body. This is where the new hose you bought will go the other end of this new hose will go the the water pipe behind the thermostat, easiest way to get to that hose is from under the car, it is above the oil filter.
Now that there is no hose on the throttle body plug up the opening with a vacuum cap ![]()
Next remove the “U” shape hose from under the manifold on the back side and place vacuum caps in place of this hose.
There is one more hose under the intake manifold that runs to the water pipe. Remove this hose from the intake manifold on the top side of the engine (this is the easiest way to get to this part of the hose) then go underneath the car and remove the hose from above the oil filter, run the new hose you bought from this spout above the oil filter to the front of the head under the upper radiator hose.
Next undo the 3 10mm bolts on the fast idle valve and put the sheet metal with rtv inbetween the fast idle valve and the manifold
Next remove the coolant line that run to the fast idle valve the bottom hose its here remove this hose and the top one and use the “U” shaped hose you removed from the back of the manifold the loop this.
After all of this fill your engine up with coolant place your intake back on and allow for the rtv to seal then start up you engine!
if all works well it should idle at around 1100 - 1250 rpm on cold start with no fluctuation!
Feel free to post and questions you have and I will answer them! ![]()
