Intake Manifold Vacuum Hose Routing for Auto Tranny for B18A1?
we just swapped a B18A1 engine with an automatic transmission into my car. some of the vacuum lines were removed and now i cant figure out where they all go.
there are two vacuum lines that come off the rear top of the intake manifold. one i know goes to the automatic transmission and the other i know goes to the egr valve. BUT, i cant figure out which tube goes to which thing.
can you guys help me? thanks!
if someone has a picture they could post for me OR clearly explain which ones goes where because they are both very similar tubes coming out of the intake manifold.
a friend said it may not matter, so if that is the case also, let me know. thanks!
http://www.imagestation.com/album/?id=4291962089
that picture is for a manual transmission. i need one for an automatic tranny. good picture otherwise… thanks!
same shit really. i have an auto as well. im converted, but all i disconnected were the egr hoses. i take it your routing diagram sticker is not under your hood anymore? ill try to take a pic of mine.
thanks xde…
all im not sure on is which tube on the intake hooks to the auto tranny and which hooks to the egr valve OR if it matters since they are all in the same vacuum hose system. i got everything else, just cant figure that part out yet.
EGR diagram. forgot exactly how they hook up. might have to remove that black cover to see. http://www.imagestation.com/album/?id=4291962089
http://www.stateofbean.org/pics/hoses.jpg
Diagram from under the hood of a 91 LS auto
ok, so i finally took a picture of what i am talking about. thanks for all the reference guides, but none of them really helped me.
in the picture there is a horitonal U shpped hose connecting two of the vacuum lines on the back of the intake manifold. one of them goes to the egr valve and the other to the automatic transmission.
i cant figure out which and thought you guys might be able to help me. thanks!
bump
