i’m just making sure that a integra 90 xsi ecu will work with a b16a, because i found a good deal on one, and want to make sure what i buy will work…
also, do i need to buy any sort of harness with the ecu, or is it plug and play?
thanks
thanks
if you r goin to put the b16 in a 90-91 teg then yes the ecu will work.
Ken
i’ll confirm that. since your car is a 90, it will work fine. The jdm xsi ecu is the ecu that is made for the b16a.
you don’t need a harness (in fact the jdm harness won’t work anyway). However you will need to add 3-4 wires to your existing harness. Read the engine swap guide.
