ok so my interior lights dont work at all on a normal basis but today the decided to work besides when you open the door. then i went in the house and came back out an tried them again and they were dim and the turned on my door light on my gauge cluster as soon as you click the light on??? also if i turn my turn signal on by clock light blinks with the turn signal and my door light goes on and off with the turn signal??? :think:
You have a grounding problem, check your dash harness grounds. 94
ok thanks… today my door light and trunk light kept blinking until i turned on my interior lights. now when i click my interior lights the door light on my dash comes on and the trunk light:shrug:
When one circuit has an effect on another seemingly unrelated circuit it is almost always because of a grounding problem, you need to check your harness grounds. 94
