interior panels on the hatch.
ey guys i was taking off the interior panels off my hatch. Because i had to remove my hatch because im painting my car. Anyways i removed the bolts, cleaned the seam siller up so i cud remove the hatch then i find the wiring harness for 3rd brake light, rear license plate light, brake lights, and ground. Well i got the main wiring harness out of the hatch i had to pull the wire through a tight tight hole. Luckily i didnt break the wire, well the other is a single wire that goes across the hatch i beleive its the license plate light. It broke so now do i solder it or krimp it? and is this wire the license plate light harness wire?
