I was driving then out of no where…my deck, clock, cig lighter, and dome lights shut off. everything else is fine. I check the fuses and theyre not blown. anyone have any ideas??
short in the dash wiring probably
a short after the fuse would cause the fuse to blow cuz so much current would be going thru the circuit without it reaching a load.
check the grounds for those circuits.
but to be safe also check under hood fuses, then under dash fuses AGAIN.
