Interior switches?
When I press the hazard switch, hazards don’t come on, and also the rear defrost switch does light up or stay in, and I purchased one when I press it it pops out is it suppose to do that? Haven’t installed it though
Do your turn signals work?
The defog button doesn’t stay in when you press it but it is supposed to light up.
Yeah my signals work, yeah I’m going to install the defog tomorrow light doesn’t turn on, also would you know anything about cruise control I turn on the switch but doesn’t show up in cluster?
The little bulb may be blown.
I dont think the cruise control shows up on the cluster until its actually active. The button should light up green iirc
correction… the defog button DOES stay in when you press it… mine does…
Should in stay in when not installed??
yes… same as the fog light button…
oh have to send back then, thanks for the help
even though they dont stay in like they should, you should still test them and see if they work…
My defrost button does not stay pressed in when on, it is different than the fog light button. According to the service manual, turning on the rear defroster activates a timer which goes for about 25 minutes then shuts off. I always understood this to be the reason the switch doesn’t stay pushed in.
