Is an alignment necessary?
I just replaced my drivers side axle for the 91 integra. Should I get the alignment done?
Nope.
No, because you didn’t replace anything or change anything that affects your wheel alignment.
un less you pulled off your tie rod
which you shoulndt have to do to pull the axel, it just needs to be disconnected from the knuckle
