Is it possible to fit a lsd to ys1 tranny ???
Is it possible to fit a lsd to a ys1 tranny for Gs-r 1992 , sure enough the b16 integra in Japan had a lsd and i am pretty sure that it was ys1 with a lsd , my question is ??? is it possible to bolt on a lsd of the type r teg on the ys1 tranny of a gs-r 1992 ??? before starting my project , i want to be sure ,
The oem LSD from a cable transmission will work. If the LSD is from a hydraulic transmission, the ys1 housing will need to be grinded slightly.
You can see the difference in the ribs in the two pictures.
Thank you very much for the tip …
[QUOTE=386;2292516]The oem LSD from a cable transmission will work. If the LSD is from a hydraulic transmission, the ys1 housing will need to be grinded slightly.
You can see the difference in the ribs in the two pictures.[/QUOTE]
thank you very much !! i will start the project my theses pics on my mind.
