well i need to lower the sucker 6" to get at the stuck tensioner bolt so i can slip the belt back on. will the jack under the oil pan be sufficient enough?
also if you have any tips i could use it. currently reading through helmes/haynes… looks like i just need to remove the mounts and disconnect some hoses and connectors. already got the distributor and ps unit/cams off
