is this a good deal?
this might need to go into product reviews… but I thought it might get looked at better here
91 LS B18a block has been “freshly” bored and honed out to 81.25 for OS CTR’s, block has been thru high pressure jet washer (clean) and completly resurfaced (decked) for excellent headgasket seal!
LS rods have been shotpeened, equipped with ARP rod bolt’s, piston’s already pressed on and balanced through out! with brand new oem rings!
LS crank has been micropolished, and rods and piston’s all balanced!
The motor has seen no miles since the build up, all it needs is bearings, oil and water pumps, and a timing belt
I can get it for 650 shipped to my door? good deal or what? I was going to buy a new engine and build it with CTR pistons. so i figured this may save me the hassle since its already built.
anyone?
someone… is this a good deal!!!
If it comes with receipts,call and check to make sure the work was done that they say.Then if everything checks out I’d pick it up.
:burnout:
good idea. oh i mean just by looks… it looks awesome here are more pics
here are pics of the block.
