ISSUE=Progress 22mm front Sway bar w/ ES endlink bushings.....
I got my 22mm progress front Sway bar in place… I have ES bushings for the d braket that mount it to the subframe and the same for the endlinks… My issue or question is I cant get the endlink nuts on the top or bottom with the bushings in place… The Sway d braket is on but not torqued down just to hold the bar in place and I have the suspension loaded on level ground… I know im supposed to have the LCA and the swaybar eyelet hole as parallel as possible went securing and putting tourque on the endlinks but I cant even get them close…,do I just need longer endlinks or what… If anyone has had this issue and knows something I dont please share… Even a pic would hook me up because im F+#king over it and almost just about to trash it and put the stock shit back on…
Wow… So u guys just like to read these threads because of all the interesting questions… But with so many looks not even a guess at an answer… Clean
The forums just came back online yesterday. Have some patience.
Just because 30 people or so viewed the thread doesn’t mean they will know what to do. If someone knows the answer, they will reply.
And you need to put a proper location in your profile per forum rules. “right where I’m standing” does not cut it.
Do you have pics to show what’s going on? Is it a new bar from Progress? Or something you bought second hand? Are you sure the sway bar isn’t upside down?
Not the best pic, but this is all I could find of mine:
Buttonwillow_073111_0004 by C o l i n, on Flickr
