I just thought i would throw up some whip pics of my latest mod. I just need to do a final molding.
Sick! Does the speedo work and everything?
why you go with brown ?
looks good man :rockon:
mmm, for me its alright, id keep it OG tho.
[QUOTE=JDM1nt2B;2140060]Looks good so far. Just need to mold the bezel to match.
Here is one I did in my DA back in 05’[/QUOTE]
now thats what im talking about.
Looks like OP is almost there. just gotta finish it up
JDM1nt2B–Just curius, How many hours do you have invested into fibber glassing that bezel?
everything functions properly! it looks very nice at night compared to stock. i have tried everything you can think of as far as modding the stock cluster and nothing ever really caught my interest that much, i have had indiglo, reverse indiglo, led conversion, and i even tried painting my needles too. I like this the best out of all the mods.
Looks good! The tan isn’t my cup o tea but whatever floats your boat!
I will be doing this mod when I get a SPoon cluster. ANd this will happen one of these days.
i’m with this guys ^^ id kill for a nice spoon cluster although i did like the s2k cluster swap as well.
I used to have everything blue, but got tired of it so i switched it up to have something different. It looks better in person (phone pics) and it looks alright with my tan gsr leathers, gold rotas, and my gold c-pillar bar.
Here is a link if you wanna check out the rest of the whip.
[QUOTE=BLKACK1;2140101]Looks like OP is almost there. just gotta finish it up
JDM1nt2B–Just curius, How many hours do you have invested into fibber glassing that bezel?[/QUOTE]
I can’t recall how long it too mod the bezel. I would guess somewhere just under 10 hours. But spread out over a lot of days. Wasn’t too hard. Just had to let the duramix set up before I could sand every time i used it. I sets up quick but I like to let it really cure before sanding and putting more on.
I took a DC bezel and cut the back part off so I had about a 1" ring. I kept the back part and tossed the front part. Mounted the cluster and taped it off. Taped the 1" dc bezel ring in place. Then I cut off about the same off of the DA bezel. Kept the front part a tossed the back part. Then mounted the DA bezel in the car. Used Duramix 4040 to “spot weld” them together. Once it set up and dried. I pulled out the whole bezel, taped off the holes from the back side and filled in with duramix from the front. The part that took the longest was sanding it so it all contoured together and looked oem.
