ITR Rear Sway Bar (22mm) In DA: Any Info Anyone?
ASR Brace
Hey Supre12 thanks for the insight and pic! I see what you mean by the peeled off sticker now…Anyway I got a question: Did you use OEM Sway bar bushing or are those Energy Suspension bushings…? Also…Did you use the DA’s Endlinks for that 22mm Type R bar…
Yup, those are OEM bushings and I did use the DA endlinks. BTW, does your DA have ABS?
did you make that bracket yourself? if not where did you get it, i like that setup
Bracket question
No thats an ASR Brace…With 22mm ITR REAR SWAY…He set up is nice cant wait till I set mine up!
so supre12’s picture attachment is of the of the ASR brace right?
Yeah…
Yeah…its an ASR Brace with ITR rear sway bar on a DA…
gotcha thanks looks like a great setup as mentioned by many
yup used all DA9 OEM parts for the rear links for my 23mm jdm bar.
So can the itr 22mm rear bar be used with da frame brackets that have been welded to the chassis for extra rigidity?
