Is it possible to mount an ITR rear sway bar using the stock LCAs?
I don’t want to switch them out since i just purchased a set of Koni Sports. Thanks
[SIZE=4]YES![/SIZE]
So it will blot up to the stock DA endlinks? How would I mount it to the subframe since the ITR is 22mm and my ST is only 19mm?
See thats the key my Illinois friend. You will have to weld or drill new holes for the D-brackets on the ITR bar. The ITR mounts to the subframe above where you would put a LTB, and between your LCA’s.
Ok…that shouldn’t be too bad. As long as the end links will bolt up fine. Do I use the ITR endlinks or the DA endlinks? Thanks
You can use your stock endlinks, good luck trying to order the new ITR endlinks. See if you can get some used ones. I would rather see ITR endlinks being bolted up instead of the DA’s. I had to suffice with the DA’s because the ITR were way on backorder and still are.
Why do you want a ITR swaybar anyway, if your not going to use ITR LCA’s? Just get a Progress bar.
[B]You can use your stock endlinks, good luck trying to order the new ITR endlinks. See if you can get some used ones. I would rather see ITR endlinks being bolted up instead of the DA’s. I had to suffice with the DA’s because the ITR were way on backorder and still are.
Why do you want a ITR swaybar anyway, if your not going to use ITR LCA’s? Just get a Progress bar. [/B]
I like using OEM parts. Plus I’m not fond of preogress after seeing the quality of their coilovers.
I agree.![]()
I agree.![]()
Finally…someone else that agrees that OEM is better than aftermarket.
Anybody have pics of this install? Will a LTB still fit?
:search: for battlecat
hye mr. burns do you have any pics of your itr sway bar in your car. i would really like to see some if you do. thanks
-aaron
edit- also where is a good place to get the progress bar, i can never find any. (nm, found them at optauto.)
I will try to get some by this weekend for sure. Everyone has been wanting to see some. Its more simple than you think.
