I know this topic has been somewhat killed in a bunch of threads such as
http://www.g2ic.com/forums/showthread.php?t=84791
and
http://www.g2ic.com/forums/showthread.php?t=148812
covered in Teg Tips:
http://www.g2ic.com/tegtips/interior/9.html
But… I thought I would post what finally worked for my 90 DA sourced from 2001 itr oem with part numbers.
…drumroll…
The G2IC ITR Short Shifter Guide for Dummies (like me):
#1: 1 @ 54113-611-505 CLIP
#2: 1 @ 54101-ST7-Z00 LEVER, CHANGE
#4: 2 @ 54105-692-010 WASHER, THRUST
#5: 2 @ 54107-SA0-010 BUSH, RR. JOINT
#12: 1 @ 54117-SD4-000 COLLAR, RR. JOINT
#13: 1 @ 54201-ST7-R00 ROD, GEARSHIFT
#14: 1 @ 54301-SR3-G00 EXTENSION, CHANGE
#23: 1 @ 90115-659-003 NUT, SELF-LOCK (8MM)
#24: 4 @ 91303-HA0-004 O-RING (11X1.9) (NOK)
#25: 1 @ 92201-08060-0H BOLT, HEX. (8X60)
All cost me about $150 shipped from a certain acura dealer in Florida ![]()
A couple of gotchas I ran into:
- make sure not to over-tighten bolt #25. I did first time and it made for crunchy shifting
- pin #28 used 8mm punch and mini-sledge to remove, worked nice. putting the new pin in was a bit of a bee-otch cuz it's newer and springier but I finally did it by 1st putting the old one back in, started driving it out a hair and drove new one in until it popped the old out.
