J-Bolts for Fuel Tank
Hey guys I really need to replace my rusted tank and I have checked at Auto Zone and Advance Auto and nobody carry the J-Bolts that hold the straps. I went to hardware stores and no luck! Where could I find these bolts???
Thanks in advance!
no luck at the junkyards? even if its not an integra maybe you can find on another honda or acura
Junkyard or Acura Dealer. Take a look at acuraautomotiveparts.org
Its insane how many OEM parts are available for older models.
im in the same boat im just going to take a torch heat some bolts up and bend them.
I checked the junkyards today and the ones they had were rusted badly as well! I wish I had a torch to do the same, its sucks how an automotive stores don’t carry a certain parts! Thanks for the site will definitely check it out!
http://www.g2ic.com/forums/showthread.php?t=193633
Get them brand new from the dealer. I did my fuel tank last summerand changed every bolt under my car with brand new ones from the dealer. It is amazing that they are still have these parts available. Everything might run you for 15 to 20 dollars. I think all my bolts including suspension came up to 60 dollars or more around there. I still have bolts in the package sitting under my car lol!
easiest solution. done it many times works great. don’t forget to use a flat washer where the bolt goes into the chassis to prevent the bolt from ripping out since it isn’t round.
sure i can get you a set that are not all rusted as we dont get the weather you guys get here in ca. let me know greazemunkey73@yahoo.com
