J32 Swap
i look at almost every site and found that nobody has done this that i know of and im going to do this. just need a little help please. i have the motor and trans right now. gotta find out what axles ecu wiring harness i need. so far i did find out that the eg mounts will work with little modification to them. let me know your input on this please. thanks!!
I know your going to need custom axles from hasport and mounts. I think they might have mounts made already, custom rad from rywire that tucks into the bumper
support, also traction bar to remove that cross member.
I know I guy named Marco that owns a shop called Krizen Industries that does J swaps into civics and integras for like $5k out the door, includes engine, labore and everything else you need.
here is a vid from a huy up in the bay area in cali that got his j swap done by Krizen industries.
http://www.youtube.com/watch?v=vVA2LM57JcA
$5K? Although that’s not a bad price for everything, you could do a lot with $5k. Cool to see the swap but I wouldn’t do it. Keep track of the build and post a thread on it. I’m sure a lot of people would find it valuable!
Hope all goes well!!
That is because most of us don’t want to cut a big A$$ hole in our hoods! These kind of swap is for guys that have money to burn, because it destroys the balance of the car. There are much better ways of reaching 260hp that does not toss handling out the window! Turbo comes to mind. You can get boosted for around half that. Or if you just want all motor, a K24 swap with cams and bolt-ons, plus a good tune would put you in the $5k area! There is no reason to swap to anything other than a B-series really unless you just really want too for those kind of numbers!
