Jack points
Ok, well, i suspect that my rear left wheel bearing is bad (squeaky noise when i drive). Now i want to jack up the car and check the wheel. Unfortunately being new to cars, i don’t know where the jack point is on my integ. I know the tow hook is point but i don’t have a floor jack… just those small ones used to change tires… where do i place this thing??
:bang:
front jack points - right behind the front tires
rear jack points - right in front of the rear tires
if still in doubt, look at the picture on the jack…show’s exactly where you should jack.
one caution: those flimsy jacks that come with the car are very unstable and i would not recommend doing any suspension work on the car with only that jack in place. use jack stands!!!
