jacking car up, safest way to do it?
About to jack my car up in my driveway
I have the driveup metal stands, jackstands…
what should I use to put under the car unless it falls??
i have some steelies in the back wiht tires on them
thanks
JAY
I’m not really understanding your question, so forgive me if I didn’t answer it right.
Buy yourself a pair of chalks(sp?) to block the rear tires. Or, you can use the front tires (w/ wheel). A big boulder should do as well.
You might want to use some wood in between the axle stand and the car if you’re planning on leaving it up for more than a day.
Regards,
Oz
If your going to start working on your own car then one of the best investments you will make will be for two good sets of jack stands. This is an area where you shouldn’t skim for a cheaper product, the life on the line here is yours!!! The way I support my car is to jack one side up and place stands in the front and rear then do the other side and leave the jack under there without the handle on it. Also, this is on level ground.
