JDM 1 peice wiring??? help
ok i baught 1 peices. the drivers side harness all 3 headlight wires are black…then the passanger there red/yellow/ and black
well i hooked them up using teg tips and it aint workin :slight_smile:
like most of the time pass. low beam works…but not drivers…then switch to high beams…passanger dosent work but drivers does…
then i change wires and other funky stuff happens…i mean it dosent seem hard to do but im having trouble…i matched it up just like what teg tips says…but it doesnt work
neone know how plz. help!
thanks
compare the order of the wires with the other side on the harness. They are the same for each side.
If the order on the passenger side is red/yellw/black, it’s the same on the driver side.
Could this simply be burnt bulbs? try to swap them or visually inspect them.
well i got them working finally :slight_smile:
cept low beams is very dim…so maybe a bad ground or wires still arnt correctly done as my drivers fog dosent work with low beams…
but theyboht are on on high beams
haha
oops
